Ce dont vous avez besoin
The manifold assembly cracked and would not let the compressor build up pressure consistently. Both gauges quit working long ago. This manifold has two quick connects and one safety valve
Mounting bracket for the air pump on the left side
Mounting bracket for the air pump on the right side
Use a pipe wrench or adjustable wrench whichever may be available. To remove the valve turn the wrench in a count clockwise direction.
Next is the removal of the two Quick connects. Again, use whatever wrench is available and turn it in a counter clockwise direction to remove those.
Manifold with pressure relief valve and two Quick connects removed
Here is teh repalcment manifold. This was the only one that was readily available for this compressor. The only difference between the old one and the replacement is that here is only room for one (1) Quick connect
Purchased the proper clamp for this repair because they were available. The old clamp can definitely not being reused. It should also be possible to use a normal worm drive hose clamp which are widely available
I used a pair of End cutting pliers to compress the end of the clamp. A pair of Combination pliers etc. should accomplish this as well.
