Aller au contenu principal
Porter-Cable 382 On/ Off Switch Replacement
Ce dont vous avez besoin
  1. Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: étape 1, image 1 de 2 Porter-Cable 382 On/ Off Switch Replacement, On/ Off Switch: étape 1, image 2 de 2
    • First, locate the three screws on the top of the sander.
    • Using a screw driver with a size T20 star bit, unscrew the screws by turning them to the left.
  2. Porter-Cable 382 On/ Off Switch Replacement: étape 2, image 1 de 2 Porter-Cable 382 On/ Off Switch Replacement: étape 2, image 2 de 2
    • Locate your on off switch and in order to remove it you must slide it out of its slot.
    • This shouldnt require any special tools, just wiggle the switch up and out.
    • Make sure this is done carefully, the switch is attached to two wires that may break if they are pulled on too hard.
  3. Porter-Cable 382 On/ Off Switch Replacement: étape 3, image 1 de 1
    • Using a spudger such as the one shown, carefully pry open the connectors as shown just enough to slide the prongs of the switch out.
    • Once both prongs are open, the on-off switch can be removed freely and replaced with a new switch.
Nick O'Sadcia
Membre depuis le 03/11/16
421 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 244
