Aller au contenu principal
Porter-Cable 382 Sander Pad Replacement
Ce dont vous avez besoin
  1. Porter-Cable 382 Sander Pad Replacement, Sander Pad: étape 1, image 1 de 1
    • When changing the sander pad, be sure to rotate the sander upside down so the pad and three highlighted screws are facing upward toward you.
    • Once the sander is upside down begin by removing your old sandpaper.
    • Once the sandpaper is removed locate the three screws on your sander pad.
  2. Porter-Cable 382 Sander Pad Replacement: étape 2, image 1 de 1
    • Remove the three, (star bolt) screws with the iFixit screw driver with a "T20" head. Be sure to hold the pad of the sander as it will rotate as you try to loosen the screws.
    • Once the screws are removed pull upward toward you and the sander pad will come apart from the device.
Nick O'Sadcia
Membre depuis le 03/11/16
421 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 8-7, Botvin Spring 2016 Membre de l'équipe UMass Dartmouth, Team 8-7, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G7
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 17
Total : 1,816
