Aller au contenu principal
Porter-Cable PC60TAG Motor Brush Replacement
Ce dont vous avez besoin
  1. Porter-Cable PC60TAG Motor Brush Replacement, Motor Brush: étape 1, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Motor Brush Replacement: étape 2, image 1 de 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Motor Brush Replacement: étape 3, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm.
  4. Porter-Cable PC60TAG Motor Brush Replacement: étape 4, image 1 de 1
    • Carefully pull the motor brush arm away from the other device.
  5. Porter-Cable PC60TAG Motor Brush Replacement: étape 5, image 1 de 1
    • Using the spudger, carefully lift the spring on the motor brush arm off of the motor brush and gently pull it to the side of the motor bush arm.
    • Be careful not to over bend the spring, as this could damage the spring and require replacement.
  6. Porter-Cable PC60TAG Motor Brush Replacement: étape 6, image 1 de 2 Porter-Cable PC60TAG Motor Brush Replacement: étape 6, image 2 de 2
    • Using the spudger, gently push the motor brush out of the arm.
  7. Porter-Cable PC60TAG Motor Brush Replacement: étape 7, image 1 de 1
    • Using a pair of needle nose pliers, gently pull the motor brush terminal off of the motor brush arm.
    • Repeat steps 3-7 on the other side of the device.
Mackenzie Fairbanks
Membre depuis le 03/24/16
564 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 Membre de l'équipe UMass Dartmouth, Team 2-2, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 825
