Aller au contenu principal
Porter-Cable PC60TAG Pinion Gear Replacement
Ce dont vous avez besoin
  1. Porter-Cable PC60TAG Pinion Gear Replacement, Pinion Gear: étape 1, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the 3/4" screw on the back cover.
  2. Porter-Cable PC60TAG Pinion Gear Replacement: étape 2, image 1 de 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Pinion Gear Replacement: étape 3, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the 1/2" screw holding on the motor brush arm. Repeat on the other side.
  4. Porter-Cable PC60TAG Pinion Gear Replacement: étape 4, image 1 de 1
    • Carefully pull the motor brush arm away from the other device, you can leave the wire connected to device. Repeat on the other side.
  5. Porter-Cable PC60TAG Pinion Gear Replacement: étape 5, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the 1 inch black retainer screw.
  6. Porter-Cable PC60TAG Pinion Gear Replacement: étape 6, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the four, 1/2" Phillips screws around the head gear.
  7. Porter-Cable PC60TAG Pinion Gear Replacement: étape 7, image 1 de 1
    • Carefully pull the head gear away from the device, and set aside.
  8. Porter-Cable PC60TAG Pinion Gear Replacement: étape 8, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the two 1/2" Phillips screws holding the head to the body on the bottom side of the grinder.
  9. Porter-Cable PC60TAG Pinion Gear Replacement: étape 9, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the other two 1/2" Phillips screws holding the head to the body on the top side of the grinder.
  10. Porter-Cable PC60TAG Pinion Gear Replacement: étape 10, image 1 de 1
    • Holding the head of the device, carefully pull the motor assembly out of the body of the device.
  11. Porter-Cable PC60TAG Pinion Gear Replacement: étape 11, image 1 de 1
    • Using a 9/16" wrench, loosen the spindle nut inside the head, from the motor assembly.
  12. Porter-Cable PC60TAG Pinion Gear Replacement: étape 12, image 1 de 1
    • Pull the motor assembly away from the head, and set aside
  13. Porter-Cable PC60TAG Pinion Gear Replacement: étape 13, image 1 de 1
    • Using a pair of needle nose pliers, remove the pinion gear from the head.
Mackenzie Fairbanks
Membre depuis le 03/24/16
564 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 Membre de l'équipe UMass Dartmouth, Team 2-2, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 9
Total : 651
