Aller au contenu principal
Porter-Cable PC60TAG Power Switch Replacement
Ce dont vous avez besoin
  1. Porter-Cable PC60TAG Power Switch Replacement, Power Switch: étape 1, image 1 de 1
    • Using the Phillips #2 screwdriver, remove the 3/4" Phillips screw on the back cover.
    • Unplug the grinder before disassembling.
  2. Porter-Cable PC60TAG Power Switch Replacement: étape 2, image 1 de 1
    • Holding the front of the device, carefully slide the back cover over the cord.
  3. Porter-Cable PC60TAG Power Switch Replacement: étape 3, image 1 de 1
    • Using the Phillips #2 screwdriver, loosen, but do not remove, the two terminal screws securing the black and white wires from the power cord.
  4. Porter-Cable PC60TAG Power Switch Replacement: étape 4, image 1 de 1
    • Careful remove each wire from the power cord from underneath the terminals.
  5. Porter-Cable PC60TAG Power Switch Replacement: étape 5, image 1 de 1
    • Using the spudger, carefully push the red power switch out of the device.
  6. Porter-Cable PC60TAG Power Switch Replacement: étape 6, image 1 de 1
    • From the other side of the device, use the spudger to carefully pry out power switch away from the device.
  7. Porter-Cable PC60TAG Power Switch Replacement: étape 7, image 1 de 1
    • Using your fingers, carefully remove each of the gold terminals from the power switch. You may need to gently wiggle the terminal back and forth in order to remove it.
Mackenzie Fairbanks
Membre depuis le 03/24/16
564 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-2, Isaacson Spring 2016 Membre de l'équipe UMass Dartmouth, Team 2-2, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 6
Total : 621
