Introduction
Almost all gas now contains up to 10% ethanol. Ethanol is one of the leading causes of damage to small gas engines. The alcohol can cause corrosion on rubber and plastic parts and can make gas powered yard tools almost impossible to start. I will illustrate how to replace the parts that are most common to fail,the primer bulb and fuel lines. While disassembled I will also illustrate how to replace the fuel filter and air filter of the Poulan P3314 2-Cycle Chainsaw.
Start by unscrewing the (3) T25 screws on the top cover
Remove the top cover and set aside
If the primer suction line was damaged, slide the carburetor back onto the mounting bolts
Attach one end of the new fuel line to the incoming fuel port on the carburetor
Move the fuel line through the primer bulb housing and hold the primer bulb up to the fuel line
Mark desired length and cut to size
Attach the larger diameter fuel line (fuel filter line) to the intake inlet on the carburetor
Attach the smaller diameter fuel line (fuel return line) to the return port on the primer bulb (longer nipple)
Slide the carburetor back onto the mounting bolts while pulling out the slack out of the fuel lines from the gas tank
32 autres ont terminé cette réparation.
14 commentaires
Any idea where I downloaded shop manuals for small engin repairs looking for stihl 039 manual
Yes I would try manuals.lib at the Google play store.
Daniel. Here you go. Hope this works out for you.
Excellent instructions
Thank You
How do you choose the best choose the best product among the ones listed here? <a href="https://onlychainsaw.com/best-scroll-saw... ">https://onlychainsaw.com/best-scroll-saw... </a>
