Introduction
This guide is applicable to BRIGHT's SunBell 2.0 Y.
If you have a different lamp please find its dedicated guide.
Ce dont vous avez besoin
Gently pull apart the two sides of the plastic case. This will reveal the circuit board an battery.
Using a Torx 6 Screw driver, loosen and store the 3 screws at the bottom side of the case.
Look for the white plastic battery connector at the base of the circuit board.
Carefully grip and pull out the white battery connector. If there is silicone or glue be mindful not to apply much force to prevent the entire connector to come loose from circuity board.
Keep battery aside.
Using a Torx 6 scredriver, remove the (2) screws holding the circuit board
With the help of a flat tool, pry the circuit board off the plastic case.
