Aller au contenu principal
Power Mac G4 Cube Modem Replacement
Ce dont vous avez besoin
  1. Power Mac G4 Cube Modem Replacement, Outer Case: étape 1, image 1 de 3 Power Mac G4 Cube Modem Replacement, Outer Case: étape 1, image 2 de 3 Power Mac G4 Cube Modem Replacement, Outer Case: étape 1, image 3 de 3
    • Release the back handle of the PowerMac. Slowly pull out the cube by holding the end of the handle. Watch for any parts that may become entangled with the outer case.
    • Push back the handle after you have taken the core out of the case.
  2. Power Mac G4 Cube Modem Replacement: étape 2, image 1 de 2 Power Mac G4 Cube Modem Replacement: étape 2, image 2 de 2
    • Place the cube upside down and remove the four T10 Torx screws on the front plate. Then remove the two screws on each side.
  3. Power Mac G4 Cube Modem Replacement: étape 3, image 1 de 1
    • Slowly lift the plate off the cube and disconnect the power cord.
  4. Power Mac G4 Cube Modem Replacement: étape 4, image 1 de 1
    • Remove the four pillars from each corner.
    • The pillars should come out fairly easily.
  5. Power Mac G4 Cube Modem Replacement, Video Card: étape 5, image 1 de 1
    • Remove the screws on the back of the VGA port.
  6. Power Mac G4 Cube Modem Replacement: étape 6, image 1 de 1
    • Remove the screw attaching the video card to the logic board.
  7. Power Mac G4 Cube Modem Replacement: étape 7, image 1 de 2 Power Mac G4 Cube Modem Replacement: étape 7, image 2 de 2
    • Remove power cord from the video card.
  8. Power Mac G4 Cube Modem Replacement: étape 8, image 1 de 1
    • Remove the power cord.
    • Remove the connector.
    • Remove the video card from the logic board.
  9. Power Mac G4 Cube Modem Replacement: étape 9, image 1 de 1
    • Carefully lift the video card from the logic board.
    • The video card should come out easily.
  10. Power Mac G4 Cube Modem Replacement: étape 10, image 1 de 2 Power Mac G4 Cube Modem Replacement: étape 10, image 2 de 2
    • Separate the video card from the adapter.
  11. Power Mac G4 Cube Modem Replacement, Modem: étape 11, image 1 de 1
    • Remove the two screws from the modem.
  12. Power Mac G4 Cube Modem Replacement: étape 12, image 1 de 1
    • Lift modem from the Logic Board.
    • The modem should come out easily.
3 autres ont terminé cette réparation.
Ryan Chun
Membre depuis le 06/24/10
1 076 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 2-7, Johann Summer 2010 Membre de l'équipe Cal Poly, Team 2-7, Johann Summer 2010
CPSU-JOHANN-R10S2G7
5 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 23
Total : 4,179
