Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Removing the Hard Drive.
Pièces
Aucune pièce spécifiée.
  1. Pull on outer latch. Lower door until it is level with your work surface.
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Remove the ribbon cable and power cable from the Hard Drive. Remove the ribbon cable and power cable from the Hard Drive.
    • Remove the ribbon cable and power cable from the Hard Drive.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. Remove the screw which holds the Hard Drive tray in place.
    • Remove the screw which holds the Hard Drive tray in place.
  5. Slide the Hard Drive tray out of the computer.
    • Slide the Hard Drive tray out of the computer.
  6. To remove the Hard Drive from the tray, unscrew the 4 screws on the bottom of the tray.
    • To remove the Hard Drive from the tray, unscrew the 4 screws on the bottom of the tray.
Ligne d'arrivée
30 autre(s) ont terminé cette réparation.
Justin Petrilli
Membre depuis le 21/01/2010
2 847 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
20 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 4
7 derniers jours : 27
30 derniers jours : 123
Total : 21,409
