Aller au contenu principal
Power Mac G4 M5183 Internal Battery Replacement
  1. Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: étape 1, image 1 de 2 Power Mac G4 M5183 Internal Battery Replacement, Opening PowerMac G4 M5183 Case: étape 1, image 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: étape 2, image 1 de 2 Power Mac G4 M5183 Internal Battery Replacement, Internal Battery: étape 2, image 2 de 2
    • Locate the battery.
    • Remove and replace battery.
    • Push the PMU button once, and only once, to reset the power supply.
Ligne d'arrivée
21 autres ont terminé cette réparation.
Justin Petrilli
Membre depuis le 01/21/10
3 114 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
25 tutoriels rédigés
4 commentaires
Nice simple post. You might make the battery number / size more obvious, for anxious nerds like me…
Thank you!
Lars-Peter Jorgensen - Réponse
Not bad, but PMU button location is not explained… the button on the front to start it?
rwwseditor - Réponse
Hi
Will a 3V Lithium battery work or must it be 3.6V?
Please advise.
Rgds
Duard
Duard Kleyn - Réponse
The PMU reset button is inside the casing, on the same circuit board as the backup battery holder. See the second photo, it's a small silver square with a circular black button inset into its top and PMU Reset in tiny white lettering beside it. The photo shows it near to the battery holder but on my model the button is further away on the far corner of the circuit board. Look around for it. Insert the new battery then press the reset ONE time only.
Robert Nicholson - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 84
Total : 25,533
