Aller au contenu principal
Power Mac G4 M5183 Logic Board Replacement
Ce dont vous avez besoin
  1. Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: étape 1, image 1 de 2 Power Mac G4 M5183 Logic Board Replacement, Opening PowerMac G4 M5183 Case: étape 1, image 2 de 2
    • Pull on outer latch.
    • Lower door until it is level with your work surface.
    • Before working on the computer make sure it is not plugged into a power supply, then touch a metal object. This discharges static electricity, which could damage the computer.
  2. Power Mac G4 M5183 Logic Board Replacement, Heat Sink: étape 2, image 1 de 2 Power Mac G4 M5183 Logic Board Replacement, Heat Sink: étape 2, image 2 de 2
    • Use the spudger to pry the clips horizontally off of the heat sink.
    • Fully remove the clips by lifting upwards.
  3. Power Mac G4 M5183 Logic Board Replacement: étape 3, image 1 de 1
    • Remove the heat sink by pulling upwards, off of the logic board.
  4. Power Mac G4 M5183 Logic Board Replacement, RAM: étape 4, image 1 de 2 Power Mac G4 M5183 Logic Board Replacement, RAM: étape 4, image 2 de 2
    • Locate the RAM modules.
    • Pull side tabs outward. The RAM will pop out of the housing.
  5. Power Mac G4 M5183 Logic Board Replacement, Graphics Card: étape 5, image 1 de 2 Power Mac G4 M5183 Logic Board Replacement, Graphics Card: étape 5, image 2 de 2
    • Remove the single screw with the Phillips #1 screwdriver.
    • Pull the graphics card up and out.
  6. Power Mac G4 M5183 Logic Board Replacement, Logic Board: étape 6, image 1 de 2 Power Mac G4 M5183 Logic Board Replacement, Logic Board: étape 6, image 2 de 2
    • Remove the six indicated cables attached to the logic board.
    • Use the spudger to remove the modem cable as indicated.
  7. Power Mac G4 M5183 Logic Board Replacement: étape 7, image 1 de 2 Power Mac G4 M5183 Logic Board Replacement: étape 7, image 2 de 2
    • Unfasten 3 Phillips screws revealed beneath the heat sink on the CPU board.
    • Carefully remove the CPU board from the Mother Board.
    • Remove the barrell nut screws from the Mother Board which held the CPU board.
    • Unfasten 3 Phillips #1 screws on Mother Board as shown in illustration 1.
    • Slide the logic board about a quarter of an inch to free it from the three retaining pins.
    • Pull upwards and outwards to fully remove the logic board.
  8. Power Mac G4 M5183 Logic Board Replacement: étape 8, image 1 de 1
    • After removing the (3) #2 philips screws, remove the (4) 1/4" hex nuts, then slide as directed and remove board.
Ligne d'arrivée
15 autres ont terminé cette réparation.
Justin Petrilli
Membre depuis le 01/21/10
3 114 Réputation
11 tutoriels rédigés
Équipe
Cal Poly, Team 13-24, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-24, Maness Winter 2010
CPSU-MANESS-W10S13G24
4 membres
25 tutoriels rédigés
3 commentaires
Are the "hex nuts" under the processor board? Could you provide a close up picture of the "nuts?"
D george - Réponse
So what is being replaced here? Wouldn’t one have to purchase a new logic board? Any info would be greatly appreciated!
Sandra Cai - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 45
Total : 18,018
