Aller au contenu principal
Power Mac G5 Top Left Cooling Fan Unit Replacement
  1. Power Mac G5 Top Left Cooling Fan Unit Replacement, Side Panel: étape 1, image 1 de 1
    • To avoid electrocution, shut down the computer. Do not open the computer or attempt to install any items inside it while the computer is on.
    • To avoid being burned, wait at least 10 minutes to allow the computer's internal components to cool.
  2. Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 2, image 1 de 1
    • Remove all the cables, including the power cables before opening the unit.
  3. Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 3, image 1 de 2 Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 3, image 2 de 2
    • Lift the tab to unlock the side panel.
    • The panel should fall out. If the panel does not fall out by itself pull a little from the edges.
  4. Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 4, image 1 de 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 4, image 2 de 3 Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 4, image 3 de 3
    • Remove the air deflector (the clear plastic cover) by pulling on the handle.
  5. Power Mac G5 Top Left Cooling Fan Unit Replacement, Top Left Cooling Fan Unit: étape 5, image 1 de 1
    • Locate the top left cooling fan unit.
  6. Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 6, image 1 de 1
    • Pull the fan straight out from its slot. You will need to remove two cables from the motherboard.
    • It may be easier to reach the cables if you remove the PCI guide (next to the fan unit) first.
  7. Power Mac G5 Top Left Cooling Fan Unit Replacement: étape 7, image 1 de 1
    • After pulling out the fan unit, the area should look like this.
20 autres ont terminé cette réparation.
Salvador Aguilar
Membre depuis le 01/21/10
2 532 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 5-8, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 5-8, Forte Winter 2010
CPSU-FORTE-W10S5G8
7 membres
30 tutoriels rédigés
1 commentaire de tutoriel
Actually you do need to remove the plastic air deflector, as the fan in question is behind it.
Tim downing - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 27
Total : 19,504
