Aller au contenu principal
Power Macintosh G3 Blue and White Graphics Card Replacement
Ce dont vous avez besoin
  1. Power Macintosh G3 Blue and White Graphics Card Replacement, Graphics Card: étape 1, image 1 de 1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White Graphics Card Replacement: étape 2, image 1 de 2 Power Macintosh G3 Blue and White Graphics Card Replacement: étape 2, image 2 de 2
    • Remove the single Phillips #1 screw circled in the picture. Set it aside for later.
    • The graphics card is outlined in red in the second image, if you are confused on where this is.
  3. Power Macintosh G3 Blue and White Graphics Card Replacement: étape 3, image 1 de 1
    • Lift the graphics card straight out of it's PCI slot.
    • Be careful not to lift sideways, you can damage the PCI slot! Try your best to lift the graphics card straight up.
2 autres ont terminé cette réparation.
[deleted]
Membre depuis le 08/28/18
26 583 Réputation
21 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 29
Total : 1,620
