Aller au contenu principal
Power Macintosh G3 Blue and White RAM Replacement
Ce dont vous avez besoin
  1. Power Macintosh G3 Blue and White RAM Replacement, RAM: étape 1, image 1 de 1
    • Unfortunately, I am unable to provide OG content for this step due to my PowerMac’s outer case being severely damaged. Once I get my new outer case I will update this step.
    • Lift the latch on the right side panel to reveal the internals of the Power Mac.
    • If you are doing this on a hard surface I highly suggest you put a mat down between the door and the ground to prevent scratches.
  2. Power Macintosh G3 Blue and White RAM Replacement: étape 2, image 1 de 1
    • Push the white tabs next to where your RAM is located away form the RAM chip itself.
    • The RAM chips should move up a tad and become somewhat loose.
    • Your RAM configuration may vary. This process is done the exact same way no matter what your RAM placement looks like.
  3. Power Macintosh G3 Blue and White RAM Replacement: étape 3, image 1 de 2 Power Macintosh G3 Blue and White RAM Replacement: étape 3, image 2 de 2
    • Pull the RAM chips out of the RAM slots.
    • That's all folks! That wasn't too hard, was it?
    • Second image: RAM remains
2 autres ont terminé cette réparation.
[deleted]
Membre depuis le 08/28/18
26 409 Réputation
21 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 16
Total : 947
