Introduction
This guide will show you how to replace the power and 3.5 mm audio adapter jacks on an iHome iP37.
Ce dont vous avez besoin
Outil utilisé dans cette étape :iOpener$19.99
Pry the exterior housing off the iHome iP37. You may need extra leverage to do this.
Remove these four 9 mm screws from the plastic casing; you will need a Phillips #2 driver to do this.
Remove the flanged 9 mm screw from the counterweight; you will need a Phillips #2 driver to do this.
Lift and remove the counterweight.
Firmly and cautiously unplug the two white 3-pin connectors from the printed circuit board.
