Aller au contenu principal
Introduction
Analog stick is one of the main component of the controller, which enables us to move or change camera angle in a game. The following steps will show you how to replace it.
  1. Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver. Remove the two bottom plastic grip covers. Remove the two bottom plastic grip covers.
    • Remove the (9) nine 9.2mm screws with a JIS #1 screwdriver.
    • Remove the two bottom plastic grip covers.
  2. Remove the (2) two 9.2mm screws with a JIS #1 screwdriver. Remove the back cover of the controller.
    • Remove the (2) two 9.2mm screws with a JIS #1 screwdriver.
    • Remove the back cover of the controller.
  3. Remove the (5) five 9.2mm screws with a JIS #1 screwdriver. Lift the motherboard and let it hang. Lift the motherboard and let it hang.
    • Remove the (5) five 9.2mm screws with a JIS #1 screwdriver.
    • Lift the motherboard and let it hang.
  4. Remove the (4) four 9.2mm screws that are holding the motherboard to the controller. Remove the motherboard.
    • Remove the (4) four 9.2mm screws that are holding the motherboard to the controller.
    • Remove the motherboard.
  5. Use the tweezers to unclip the four metal teeth of the analog stick. Use the soldering iron to desolder the analog stick sensor module from the back of the motherboard.
    • Use the tweezers to unclip the four metal teeth of the analog stick.
    • Use the soldering iron to desolder the analog stick sensor module from the back of the motherboard.
    • Place the new analog stick sensor module and solder it back.
Marjan Mehedi
Membre depuis le 27/09/2017
119 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S14-G4, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G4, Boczar Fall 2017
USFT-BOCZAR-F17S14G4
4 membres
5 tutoriels rédigés
Hi I’m looking those analog stick but I’m only finding the plastic and they are to big they are called different or something ?
Jose nobkes - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 9
7 derniers jours : 34
30 derniers jours : 127
Total : 1,993
