Aller au contenu principal
PowerA Spectra Infinity Enhanced Vibration Motors Replacement
Ce dont vous avez besoin
  1. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: étape 1, image 1 de 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Motherboard: étape 1, image 2 de 2
    • Flip the controller so the back is facing up.
  2. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 2, image 1 de 1
    • Remove the eight 10 mm screws from the back of the controller using a Phillips #0 screwdriver.
  3. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 3, image 1 de 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 3, image 2 de 2
    • Unlock the trigger locks before removing the backplate.
    • This will make taking the plate off easier.
    • Use your fingers and carefully remove the backplate.
  4. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 4, image 1 de 1
    • Remove the two 10 mm screws connecting the motherboard to the faceplate using a Phillips #0 screwdriver.
  5. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 5, image 1 de 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 5, image 2 de 2
    • Use your hand to separate the motherboard from the face plate.
  6. PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: étape 6, image 1 de 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement, Vibration Motors: étape 6, image 2 de 2
    • Remove the four 7.9 mm screws using a Phillips #0 screwdriver.
  7. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 7, image 1 de 2 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 7, image 2 de 2
    • Use tweezers to unplug the small plug connecting the motors to the motherboard.
    • A firm grip may be necessary for this step.
  8. PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 8, image 1 de 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 8, image 2 de 3 PowerA Spectra Infinity Enhanced Vibration Motors Replacement: étape 8, image 3 de 3
    • Remove the completely freed vibration motor from the motherboard.
2 autres ont terminé cette réparation.
Kevyn Jorge
Membre depuis le 03/22/24
1 012 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-5, Botvin Spring 2024 Membre de l'équipe UMass Dartmouth, Team 6-5, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G5
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 27
Total : 341
