Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. Remove the Ni-Cad battery from the PowerBook 180. Slide the arrows toward the front of the computer until the battery can slide out.
    • Remove the Ni-Cad battery from the PowerBook 180.
    • Slide the arrows toward the front of the computer until the battery can slide out.
  2. Removing the screws securing the bottom plate from the PowerBook 180. There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
    • Removing the screws securing the bottom plate from the PowerBook 180.
    • There are 5 Torx T8 screws, 4 of which are located on the bottom and 1 on the back above the modem port.
  3. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  4. Your computer should look like the two pictures after the bottom plate is removed. Your computer should look like the two pictures after the bottom plate is removed.
    • Your computer should look like the two pictures after the bottom plate is removed.
  5. Locate the modem board, which is next to the DC-in port. There are two Torx T8 screws marked in red in the pictures.  Remove these screws and pull up on the modem board to remove.
    • Locate the modem board, which is next to the DC-in port.
    • There are two Torx T8 screws marked in red in the pictures. Remove these screws and pull up on the modem board to remove.
    • To reassemble your PowerBook, follow these instructions in reverse.
3 autre(s) ont terminé cette réparation.
Jack Byrnes
Membre depuis le 17/10/2010
1 223 Réputation
2 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
293 membres
929 tutoriels rédigés
Great guide. Worked for me of the Powerbook 140. Thanks!
Jack - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 1,102
