Aller au contenu principal
PowerBook G3 Lombard Hard Drive Replacement
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. PowerBook G3 Lombard Hard Drive Replacement, Keyboard: étape 1, image 1 de 1
    • Turn the computer so that the ports are facing you.
    • If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
  2. PowerBook G3 Lombard Hard Drive Replacement: étape 2, image 1 de 1
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • Make sure you have removed the laptop battery and CD/DVD module from the expansion bays before proceeding.
  3. PowerBook G3 Lombard Hard Drive Replacement: étape 3, image 1 de 1
    • Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
    • In order to replace the keyboard, you must first remove the modem.
  4. PowerBook G3 Lombard Hard Drive Replacement, Heat Shield: étape 4, image 1 de 1
    • Remove the three silver Phillips screws that attach the heat shield to the internal metal framework.
  5. PowerBook G3 Lombard Hard Drive Replacement: étape 5, image 1 de 1
    • Lift the heat shield up and pull it toward you.
  6. PowerBook G3 Lombard Hard Drive Replacement: étape 6, image 1 de 1
    • Your laptop should look approximately like this.
  7. PowerBook G3 Lombard Hard Drive Replacement, Modem: étape 7, image 1 de 1
    • Remove the two silver Phillips screws from the modem.
  8. PowerBook G3 Lombard Hard Drive Replacement: étape 8, image 1 de 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to get under the modem's edge and pry it up from its socket as shown in the picture.
  9. PowerBook G3 Lombard Hard Drive Replacement: étape 9, image 1 de 1
    • Disconnect the cable from the right side of the modem.
  10. PowerBook G3 Lombard Hard Drive Replacement: étape 10, image 1 de 1
  11. PowerBook G3 Lombard Hard Drive Replacement, Processor: étape 11, image 1 de 1
    • Use a spudger, the tips of your fingers, or a flat non-metal tool to pry up the processor's right side.
  12. PowerBook G3 Lombard Hard Drive Replacement: étape 12, image 1 de 1
    • Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
    • This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
  13. PowerBook G3 Lombard Hard Drive Replacement: étape 13, image 1 de 1
  14. PowerBook G3 Lombard Hard Drive Replacement, Hard Drive: étape 14, image 1 de 1
    • Grasp the orange cable at the left end of the hard drive and disconnect it from the logic board.
    • Try to grasp the cable on the plastic connector rather than on the flexible cable section.
  15. PowerBook G3 Lombard Hard Drive Replacement: étape 15, image 1 de 1
    • Grasp the plastic tab and pull the hard drive up and to the left, making sure that the metal bracket doesn't catch on the black plastic casing.
2 autres ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 09/24/09
1 Réputation
636 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 4,600
