Introduction
This guide shows the hidden screws you must remove when replacing the keyboard.
Ce dont vous avez besoin
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Remove the four Phillips screws from the memory door.
Slide the memory door away from the memory compartment.
On the keyboard, remove the F1, F2, F11, and F12 keys.
This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
4 autres ont terminé cette réparation.
