Aller au contenu principal
PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement
Ce dont vous avez besoin
  1. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement, Battery: étape 1, image 1 de 1
    • Use a coin to turn the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement, Upper Case: étape 2, image 1 de 1
    • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
  3. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 3, image 1 de 1
    • Remove the memory compartment cover.
    • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
    I had 7mm screws here instead of 12mm. Did without them till later.
    gepkes - Réponse
    I have an Aluminum PowerBook G4 1.67Ghz since 2006.
    3/4 (from bottom to top) of the LCD becomes either black or is jumbled each time I turn on the MAC or move the screen. I need to press the LCD at several locations in order for this problem to go.... any advice ?
    Polanskiman - Réponse
    re: Polanskiman; this is usually caused by a loose ribbon connector on the rear of the LCD. Open up the display, remove the LCD, lay flat and re-connect the ribbon plug.
    aaiverson - Réponse
  4. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 4, image 1 de 1
    • Rotate the computer 90 degrees clockwise so the power receptacle faces you.
    • Remove the three 3 mm Phillips screws along the edge of the lower case.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
  5. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 5, image 1 de 1
    • Turn the computer 90 degrees clockwise so the hinge faces you.
    • Remove the lower 5 mm Phillips screw on each side of the hinge (two total).
  6. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 6, image 1 de 1
    • Rotate the computer 90 degrees clockwise so the ports face you.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
  7. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 7, image 1 de 1
    • Turn the computer over and open the display.
    • Remove the two 4.2 mm long, 1.5 mm hex screws at the top corners of the upper case (two total).
    • A T6 Torx driver will work, but repeated use will strip the screws.
  8. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 8, image 1 de 1
    • Grasp the back corners of the upper case and pull up.
    • Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 9, image 1 de 1
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
    First of all, awesome guide. I am using it in July 2015, and there is no way I could have successfully navigate the typical Apple laptop Rubik's cube of Powerbook maintenance.
    Second, there is a REAL trick to removing the upper case here, and it involves knowing what those stupid internal metal catches look like so you can free them without folding your aluminum case into a pretzel.
    WildBill - Réponse
  10. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 10, image 1 de 1
    • Remove the amber tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board by pulling up on the connector.
    • Remove the upper case from the computer.
    in my g4 there is also a big transparent ribbon (for keyboard?), to the right of the amber trackpad ribbon, that i disconnected before removing case cover.
    [deleted] - Réponse
    re: ykuwabara; this is due to the differences between the Model A1095 (yours) and the newer A1138 (illustrated here). The A1138 combines the keyboard and trackpad signals into one cable.
    aaiverson - Réponse
  11. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement, Left Ambient Light Sensor: étape 11, image 1 de 1
    • Remove the two 3 mm Phillips screws securing the left ambient light sensor. One is silver and one is black, or both black.
    • Disconnect the cable from the Logic board and remove the left ambient light sensor from your computer.
  12. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement, Left Speaker: étape 12, image 1 de 1
    • Remove the 4 mm hex nut securing the left speaker.
  13. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 13, image 1 de 1
    • Disconnect the left speaker cable.
    Mine did not have a plug here, the speaker is soldered on.
    Simon Baldwin - Réponse
  14. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement, PC Card Cage: étape 14, image 1 de 1
    • Remove the four Phillips screws from the PC card cage.
    • The two longer screws go on the right side of the card cage.
  15. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 15, image 1 de 1
    • Disconnect the PC card cable from the logic board.
  16. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 16, image 1 de 1
    • Lift the PC card cage up and remove it from the computer.
    • When replacing the PC card cage, make sure you attach it to the post on the metal eject button.
    I couldn't disconnect the cage from the eject button here. Possibly because the speaker is still attached but its hard to see how the button is attached to the cage.
  17. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement, DC & Sound Card: étape 17, image 1 de 1
    • Remove the silver Phillips screw.
    • Remove the 5 mm hex nut screw.
    • Disconnect the power cable and the speaker cable from the DC & sound board (connectors highlighted in yellow boxes).
  18. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 18, image 1 de 1
    • Lift the DC & sound card out of lower case, but don't remove it entirely as there are still cables connected.
  19. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 19, image 1 de 1
    • Disconnect the power cable from the DC & sound card board.
  20. PowerBook G4 Aluminum 15" 1.67 GHz DC & Sound Card Replacement: étape 20, image 1 de 1
    • Disconnect the RJ-11 cable from the modem.
    My replacement part fot the DC / Sound board was new, and did not include the RJ-11 connector and cable. From the old part, the RJ-11 port is the gray connector next to the power connector. Grasp the RJ-11 connector, and slide it off of the DC / Sound board (there is no retainer nor clips, friction holds it in place). The RJ-11 connector can then be moved to the new part, just sliding into the square cut-out next to the power connector.
    Ben Ruiz - Réponse
18 autres ont terminé cette réparation.
Pièces jointes
4 commentaires
The Tools Used list specifies a #6 Torx wrench, but in step 7 it says a 1.5mm hex wrench is preferred. This is good to know ahead of time since a #6 Torx wrench is not available from the local hardware store, but a 1.5mm hex wrench is.
ewoudenberg - Réponse
THANKS for the clear, accurate help! your tutorial did the job - bravo!
valleydave3 - Réponse
Thanks you guys. I never thought I could fix my own Mac 'till I came here. I did have to mix two different procedures as the inside of my PowerBook G4 was not exactly like the one in either.
Thank you!
JOhnZ
johnzip - Réponse
Great guide - i fixed my PB G4 1,67 without any troubles. My DC-in board had a burned through capacitor. Now it´s loading again the battery and recognizes the powerplug.
Thank you!
Guenther Roppele - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 27,806
