Introduction
Prereg only.
Tools
Parts
No parts specified.
Remove the two 6mm long, 1.5 mm hex screws near the lower left and right corners of the display.
With your spudger still inserted under the front display bezel, run it around the lower left corner of the display.
Rotate the spudger away from yourself to pry the rear display bezel off the aluminum tabs on the front display bezel.
Work your way down the side of the display until the rear display bezel has been separated from the front display bezel.
Repeat the previous steps to separate the right side of the rear display bezel from the display.
Use your spudger to pry the plastic retaining clips on the rear display bezel over the raised aluminum tabs on the front display bezel.
At this point, the clips on the left and right edges of the rear display bezel should be free from the raised aluminum tabs on the front display bezel. If they are not, use a spudger to pry them past the front display bezel.
