Aller au contenu principal
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement
Ce dont vous avez besoin
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: étape 1, image 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Battery: étape 1, image 2 de 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, Memory Door: étape 2, image 1 de 1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: étape 3, image 1 de 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement: étape 3, image 2 de 2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: étape 4, image 1 de 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: étape 4, image 2 de 3 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) RAM Replacement, RAM: étape 4, image 3 de 3
    • Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
    • Pull the RAM chip away from its socket and remove it from the logic board.
    • Repeat this process for the other RAM chip, if present.
24 autres ont terminé cette réparation.
Pièces jointes
Un commentaire
What is the maximum ram that I can bump up this system to?
Legendary Ocelot - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 19
Total : 8,338
