Introduction
56k internal modem, standard on all models.
Ce dont vous avez besoin
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Use your thumbs to slide the RJ-11 board slightly away from the DC-In board.
Presque terminé !
