Introduction
This guide shows the hidden screws you must remove when replacing the keyboard.
Ce dont vous avez besoin
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Remove the two Phillips screws securing the electronic track pad button to the lower case.
3 autres ont terminé cette réparation.
Pièces jointes
2 commentaires
Excellent detailed instructions and cautions. Even the magnified pictures are very good. A bit more complicated than a Dell or Toshiba. Mahalo.
there’s a connector for the power button on the orange ribbon that doesn’t slip through slit - WTF?
