Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
How to remove the hard drive, along with its cable and bracket from your computer.
  1. Locate the battery release tab on the underside of the G4. Slide the battery release tab to the left and lift the battery out of the computer.
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. Remove the seven T8 Torx screws from the lower case. Using your thumbs, slide the lower case toward the front of the computer.
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  4. To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  5. Remove the hard drive by lifting the left edge up and out of the computer.
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  6. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
10 autre(s) ont terminé cette réparation.
Pièces jointes
iRobot
Membre depuis le 24/09/2009
1 Réputation
643 tutoriels rédigés
Équipe
The Home Depot Membre de l'équipe The Home Depot
Community
22 membres
1 750 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 13,596
