Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Just remove a few Phillips screws, and the bottom case slides off.
    • Turn the G4 over.
    • Remove the eight Phillips screws from the lower case.
  1. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  2. Using your thumbs, slide the lower case away from you.
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
Pièces jointes
iRobot
Membre depuis le 24/09/2009
1 Réputation
643 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 14
Total : 4,849
