Aller au contenu principal
PowerLead Puto PLD003 Tripod Clip Replacement
Ce dont vous avez besoin
  1. PowerLead Puto PLD003 Tripod Clip Replacement, Side Panel: étape 1, image 1 de 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Tripod Clip Replacement: étape 2, image 1 de 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Tripod Clip Replacement: étape 3, image 1 de 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Tripod Clip Replacement: étape 4, image 1 de 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: étape 5, image 1 de 2 PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: étape 5, image 2 de 2
    • Apply pressure upwards to remove the tripod clip.
Justin Tew
Membre depuis le 03/31/16
767 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 153
