Aller au contenu principal
PowerLead Puto PLD003 Zoom Button Replacement
Ce dont vous avez besoin
  1. PowerLead Puto PLD003 Zoom Button Replacement, Side Panel: étape 1, image 1 de 1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Zoom Button Replacement: étape 2, image 1 de 1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Zoom Button Replacement: étape 3, image 1 de 1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Zoom Button Replacement: étape 4, image 1 de 1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: étape 5, image 1 de 2 PowerLead Puto PLD003 Zoom Button Replacement, Zoom Button: étape 5, image 2 de 2
    • Remove the 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Zoom Button Replacement: étape 6, image 1 de 1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Zoom Button Replacement: étape 7, image 1 de 1
    • Apply pressure to the back panel, pulling away from the camera to remove it.
  8. PowerLead Puto PLD003 Zoom Button Replacement: étape 8, image 1 de 2 PowerLead Puto PLD003 Zoom Button Replacement: étape 8, image 2 de 2
    • Remove the final 4 mm Phillips #1 screw holding the screen in place.
    • This screw is very small and hard to see.
  9. PowerLead Puto PLD003 Zoom Button Replacement: étape 9, image 1 de 1
    • Carefully apply pressure away from the camera to the screen to detach it from the body.
    • The white cord should still be connected to the body.
    • OPTIONAL: Remove the screen to make accessing the zoom button easier.
  10. PowerLead Puto PLD003 Zoom Button Replacement: étape 10, image 1 de 1
    • Remove the three 4 mm Phillips #1 screws holding the top panel in place.
  11. PowerLead Puto PLD003 Zoom Button Replacement: étape 11, image 1 de 2 PowerLead Puto PLD003 Zoom Button Replacement: étape 11, image 2 de 2
    • Push upward on the top panel to remove it from the body of the camera.
  12. PowerLead Puto PLD003 Zoom Button Replacement: étape 12, image 1 de 2 PowerLead Puto PLD003 Zoom Button Replacement: étape 12, image 2 de 2
    • Remove the two 4 mm Phillips #1 screws holding the circuit board in place.
    • Do not remove the silver screws.
  13. PowerLead Puto PLD003 Zoom Button Replacement: étape 13, image 1 de 1
    • Lift the circuit board out of the plastic casing.
    • Gently pull on the zoom button to remove it from the circuit board.
Justin Tew
Membre depuis le 03/31/16
767 Réputation
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 183
