Aller au contenu principal
PowerShot G7 X Mark II Front Cover Replacement
Ce dont vous avez besoin
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: étape 1, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: étape 1, image 2 de 2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: étape 2, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 2, image 2 de 2
    • Use a Phillips #000 screwdriver to remove five 3mm screws from under the LCD screen.
  3. PowerShot G7 X Mark II Front Cover Replacement: étape 3, image 1 de 1
    • Use a Phillips #000 screwdriver to remove one 3mm screw on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: étape 4, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 4, image 2 de 2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: étape 5, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 5, image 2 de 2
    • Carefully remove the back cover off of the camera by hand, minding the ribbon cable attached to the camera body. If the cover does not detach, use a spudger to pry it off.
    • Use the spudger tool to open the ZIF connector attaching the ribbon cable to the camera body.
  6. PowerShot G7 X Mark II Front Cover Replacement: étape 6, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 6, image 2 de 2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: étape 7, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 7, image 2 de 2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 1 de 3 PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 2 de 3 PowerShot G7 X Mark II Front Cover Replacement: étape 8, image 3 de 3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: étape 9, image 1 de 2 PowerShot G7 X Mark II Front Cover Replacement: étape 9, image 2 de 2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: étape 10, image 1 de 1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: étape 11, image 1 de 1
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: étape 12, image 1 de 1
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
2 autres ont terminé cette réparation.
Brandon
Membre depuis le 02/15/17
596 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 12-3, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 membres
4 tutoriels rédigés
Un commentaire
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 37
Total : 3,635
