Aller au contenu principal
PowerShot G7 X Mark II LCD Screen Replacement
Ce dont vous avez besoin
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: étape 2, image 1 de 1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: étape 3, image 1 de 1
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
  4. PowerShot G7 X Mark II LCD Screen Replacement: étape 4, image 1 de 1
    • The screen is detached and can now be replaced.
5 autres ont terminé cette réparation.
Brandon
Membre depuis le 02/15/17
644 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 12-3, Eyestone Spring 2017 Membre de l'équipe USF Tampa, Team 12-3, Eyestone Spring 2017
USFT-EYESTONE-S17S12G3
3 membres
4 tutoriels rédigés
5 commentaires de tutoriel
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - Réponse
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - Réponse
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - Réponse
on ebay or amazon. you can order it
nicole -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 31
30 derniers jours : 155
Total : 10,855
