Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
Ce dont vous avez besoin
  1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: étape 1, image 1 de 2 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: étape 1, image 2 de 2
    • Plug in the tree.
    • Use a Christmas light function tester to check the fuse on a light that is not bright.
    • The red light on the function tester will not light up if the fuse is dead.
  2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 2, image 1 de 1
    • Unplug the tree from the outlet.
  3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 3, image 1 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 3, image 2 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 3, image 3 de 3
    • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
  4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 4, image 1 de 1
    • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
    • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
  5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 5, image 1 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 5, image 2 de 3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 5, image 3 de 3
    • Carefully insert the working fuse back into the tree plug, and put the cover on.
  6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 6, image 1 de 1
    • Plug the tree back into the outlet.
  7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: étape 7, image 1 de 1
    • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
    • The red light will appear whether the bulb itself is working or not.
Thank you for using this guide!
Elizabeth Harvey
Membre depuis le 10/05/20
179 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 105
Total : 4,252
