How to prep a black wire for XYZ job.
Measure out a 10cm length of wire.
Use a pair of flash cutters to carefully cut through the wire.
Caution: the wire must be no longer than 10.5cm and no shorter than 9.5cm in length.
Measure 20mm from either end of the wire.
With the flash cutters remove the instulation that is covering the wire.
Be careful not to cut to deep because you will damage the wire strands inside.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Aperçu
