Aller au contenu principal
Prep Black Wire
Ce dont vous avez besoin
  1. Prep Black Wire, Wire: étape 1, image 1 de 1
    • Locate QCPN#10669 which is a black hookup wire.
  2. Prep Black Wire: étape 2, image 1 de 3 Prep Black Wire: étape 2, image 2 de 3 Prep Black Wire: étape 2, image 3 de 3
    • Measure out a 10cm length of wire.
    • Use a pair of flash cutters to carefully cut through the wire.
    • Caution: the wire must be no longer than 10.5cm and no shorter than 9.5cm in length.
  3. Prep Black Wire: étape 3, image 1 de 1
    • Your wire should look like this now. #testedit
  4. Prep Black Wire: étape 4, image 1 de 2 Prep Black Wire: étape 4, image 2 de 2
    • Measure 20mm from either end of the wire.
    • With the flash cutters remove the instulation that is covering the wire.
    • Be careful not to cut to deep because you will damage the wire strands inside.
  5. Prep Black Wire: étape 5, image 1 de 2 Prep Black Wire: étape 5, image 2 de 2
    • Measure 10mm from the other side of the wire.
    • Remove the insulation from the wire with a pair of flash cutters.
  6. Prep Black Wire: étape 6, image 1 de 1
    • Your finished wire should now look like this.
    • Remember to twist of the ends of the wire with your fingers so that the wire strands are not loose.
You are finished.
6 autres ont terminé cette réparation.
Russell Frampton
Membre depuis le 07/30/13
356 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 451
