Aller au contenu principal
ProScan PLT7223G Motherboard Replacement
Ce dont vous avez besoin
  1. ProScan PLT7223G Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Remove both 4 mm screws from the top of the tablet using a PH00 screw driver.
  2. ProScan PLT7223G Motherboard Replacement: étape 2, image 1 de 1
    • Use the blue opening tool to pry the tablet open.
  3. ProScan PLT7223G Motherboard Replacement: étape 3, image 1 de 2 ProScan PLT7223G Motherboard Replacement: étape 3, image 2 de 2
    • Remove all yellow tape from the motherboard.
  4. ProScan PLT7223G Motherboard Replacement: étape 4, image 1 de 3 ProScan PLT7223G Motherboard Replacement: étape 4, image 2 de 3 ProScan PLT7223G Motherboard Replacement: étape 4, image 3 de 3
    • With the soldering tool remove the speaker wires, battery wires and gray wire that are connected to the motherboard.
    • Pay close attention to where each wire goes, so that you reconnect them in the correct order.
  5. ProScan PLT7223G Motherboard Replacement: étape 5, image 1 de 3 ProScan PLT7223G Motherboard Replacement: étape 5, image 2 de 3 ProScan PLT7223G Motherboard Replacement: étape 5, image 3 de 3
    • Lift all three ZIF connectors to disconnect the ribbon wire.
  6. ProScan PLT7223G Motherboard Replacement: étape 6, image 1 de 1
    • Use a PH00 screw driver to remove the three 4 mm screws holding the motherboard down.
  7. ProScan PLT7223G Motherboard Replacement: étape 7, image 1 de 1
    • Lift the motherboard off the device.
2 autres ont terminé cette réparation.
Daniel Hernandez
Membre depuis le 01/12/16
315 Réputation
1 tutoriel rédigé
Un commentaire
Once the motherboard is out, what do you do ? Where do I go? More information would be appreciated.
rainbowsend14 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,464
