Aller au contenu principal
Promowide SP1790 Charging Port Replacement
Ce dont vous avez besoin
  1. Promowide SP1790 Charging Port Replacement, Battery Wire: étape 1, image 1 de 1
    • Locate the six screws on the back of the speaker.
  2. Promowide SP1790 Charging Port Replacement: étape 2, image 1 de 1
    • Unscrew each of the six screws, then set them aside.
  3. Promowide SP1790 Charging Port Replacement: étape 3, image 1 de 1
    • Gently remove the back cover of the speaker.
  4. Promowide SP1790 Charging Port Replacement: étape 4, image 1 de 1
    • Place the speaker upside down.
    • Remove the battery cover located in the center of the speaker.
  5. Promowide SP1790 Charging Port Replacement: étape 5, image 1 de 1
    • Locate and remove the four screws under each of the pads near the power socket.
  6. Promowide SP1790 Charging Port Replacement: étape 6, image 1 de 1
    • Gently remove the bottom.
    • Do NOT pull out or damage wires.
  7. Promowide SP1790 Charging Port Replacement: étape 7, image 1 de 1
    • Remove the single motherboard screw.
  8. Promowide SP1790 Charging Port Replacement: étape 8, image 1 de 1
    • Remove both of the screws holding the power socket to the bottom chassis.
  9. Promowide SP1790 Charging Port Replacement: étape 9, image 1 de 1
    • Desolder and remove the old wire.
    • Insert the new wire and solder it into place.
2 autres ont terminé cette réparation.
Joseph Malone
Membre depuis le 06/01/16
160 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 955
