Introduction
You may need to replace your helicopter's drive gears if they become damaged or stripped. Replacing the gears will require you to completely disassemble your helicopter, so make sure to place small parts and screws in a safe place to avoid losing them.
Ce dont vous avez besoin
Place the tweezers on the sides of the links and pull straight away from the top point of connection.
Remove the two 5.0 mm Phillips #00 screws from the rotors.
The blades will fall off when the screws have been removed.
Remove the two 8 mm Phillips #00 screws between the motor casing and the body.
2 autres ont terminé cette réparation.
