Aller au contenu principal
Protocol Dronium Two HD Camera Replacement
Ce dont vous avez besoin
  1. Protocol Dronium Two HD Camera Replacement, Landing Gear: étape 1, image 1 de 1
    • Turn device off by moving the selector switch to the left.
  2. Protocol Dronium Two HD Camera Replacement: étape 2, image 1 de 2 Protocol Dronium Two HD Camera Replacement: étape 2, image 2 de 2
    • Place one hand on the drone and carefully remove the landing gear with the other hand.
    • Be gentle as to not break off the studs on the landing gear.
  3. Protocol Dronium Two HD Camera Replacement, HD Camera: étape 3, image 1 de 2 Protocol Dronium Two HD Camera Replacement, HD Camera: étape 3, image 2 de 2
    • Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
  4. Protocol Dronium Two HD Camera Replacement: étape 4, image 1 de 2 Protocol Dronium Two HD Camera Replacement: étape 4, image 2 de 2
    • Push the battery cover away from the drone and carefully open it up.
  5. Protocol Dronium Two HD Camera Replacement: étape 5, image 1 de 2 Protocol Dronium Two HD Camera Replacement: étape 5, image 2 de 2
    • Carefully remove the two Phillips 5.35 mm screws holding the camera to the battery cover.
  6. Protocol Dronium Two HD Camera Replacement: étape 6, image 1 de 1
    • Close the battery cover by pulling it towards you. Then, gently pull the camera towards you, freeing it from the battery cover.
William Tietz
Membre depuis le 01/18/17
101 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 219
