Introduction
If one or more motors on your drone are not responding, this guide will show you how to replace them.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Heavy-Duty Spudger$4.99
Use the heavy duty spudger tool to pry off metal caps by pushing the spudger up into the cap.
Remove Blade Guards by unscrewing two 13 millimeter screws using Philips #0. Pull out the guards. Repeat the steps for the other three corners.
Remove the two 4mm Philips screws from the motor.
Separate the motor from the plastic motor holder.
Un commentaire
what I need to know is where can I buy the plastic motor holder. This would be for a Galileo stealth drone. can someone please help me with this. markkermoyan@gmail.com
