Aller au contenu principal
Protocol Galileo Stealth Housing Replacement
Ce dont vous avez besoin
  1. Protocol Galileo Stealth Housing Replacement, Propeller: étape 1, image 1 de 1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Housing Replacement: étape 2, image 1 de 1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Housing Replacement: étape 3, image 1 de 1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Housing Replacement: étape 4, image 1 de 1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Housing Replacement, Housing: étape 5, image 1 de 2 Protocol Galileo Stealth Housing Replacement, Housing: étape 5, image 2 de 2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Housing Replacement: étape 6, image 1 de 1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
Matthew Selting
Membre depuis le 02/15/18
432 Réputation
4 tutoriels rédigés
Équipe
UW Stout, Team S8-G4, Ogden Spring 2018 Membre de l'équipe UW Stout, Team S8-G4, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 124
