Aller au contenu principal
Protocol Kaptur GPS Battery Replacement
Ce dont vous avez besoin
  1. Protocol Kaptur GPS Battery Replacement, Battery: étape 1, image 1 de 2 Protocol Kaptur GPS Battery Replacement, Battery: étape 1, image 2 de 2
    • The battery is accessible through the back of the drone.
    • Press the tabs on both sides of the white stripe to pull the battery out.
  2. Protocol Kaptur GPS Battery Replacement: étape 2, image 1 de 3 Protocol Kaptur GPS Battery Replacement: étape 2, image 2 de 3 Protocol Kaptur GPS Battery Replacement: étape 2, image 3 de 3
    • Remove the screws starting with the three smaller ones on the top part of the battery.
    • Remove the three screws on the other side.
    • There are two screws tucked under where the yellow circle is located. You will need to remove the other screws first before you get to these two.
    • There should be one 7 mm Phillips head screw, three 6 mm Phillips head screws, and four 5 mm Phillips head screws.
  3. Protocol Kaptur GPS Battery Replacement: étape 3, image 1 de 2 Protocol Kaptur GPS Battery Replacement: étape 3, image 2 de 2
    • Remove the top piece, and gently pry the two halves apart. Divide the sticker if necessary.
  4. Protocol Kaptur GPS Battery Replacement: étape 4, image 1 de 2 Protocol Kaptur GPS Battery Replacement: étape 4, image 2 de 2
    • The battery is now removable from its container.
    • During reassembly, make sure the outlet is returned to its holder and faces the correct direction.
4 autres ont terminé cette réparation.
Connor Woitte
Membre depuis le 02/15/18
858 Réputation
3 tutoriels rédigés
Équipe
UW Stout, Team S8-G6, Ogden Spring 2018 Membre de l'équipe UW Stout, Team S8-G6, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G6
3 membres
4 tutoriels rédigés
5 commentaires
Any chance someone’s found a new internal battery for these? Stock ones break down incredibly fast and don’t want to take a charge
Jeff - Réponse
This Kaptur is a $30 drone pretending to be a $150!quad . I have had 2 now 1 & a return and I can say with confidence that this is the worst quad I’ve ever had the displeasure of piloting . Cheap doesn’t do this lemon justice . If you can actually get someone on the phone get your money back there are way better options out there at a lower price point . Even when this pig is airborne it has horrible gps lock and can’t handle any wind over 2mph I believe this was a good idea gone wrong . For you own health and nerves move on do not buy .
Jeremyrogers - Réponse
You’re obviously a novice pilot. I own 5 and they all work flawlessly and are well made. When it comes to people complaining about Drones, the reason is usually their own fault. They tried to fly in high winds, didn’t calibrate the drone before use, didn’t wait until enough satellites were locked in before take off, used a phone instead of the original transmitter to control the drone or just plain panicked after the drone went into automatic return or they lost the line of sight and orientation etc.
Raider 707 -
I love this drone, It’s not my first got one before they became popular. I came from flying 450-500 C/P RC Helicopters. If you can fly RC Heli’s or planes you will navigate this like it’s almost hands-free. Seriously that smooth and easy to pilot. For those that have never flown anything RC before then don’t take what I am saying literally because I am referring this to people that actually have flown much harder to navigate RC flyers.
Salvatore Smisek - Réponse
Ok so I do love this drone. I'm just having problems with the recording video or pictures any suggestions
Adam Ayala - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 13
Total : 2,546
