Introduction
This guide will help you replace your lens if they get scratched or broken.
Ce dont vous avez besoin
Remove the phone slide from the virtual reality lens.
Take the outside cover off using a plastic opening tool.
You will need to remove the adjustable lens lever on top of the virtual reality lens.
Using a tweezers, you will need to separate the tooth gears and remove them so the lens can fall freely out.
Pull the lens case out from the front of the headset.
