Aller au contenu principal
Protocol TerraCopter EVO Drone Motor Replacement
Ce dont vous avez besoin
  1. Protocol TerraCopter EVO Drone Motor Replacement, Drone Motor: étape 1, image 1 de 1
    • Orientate the drone to where the black side of the drone face upwards.
    • On the bottom side of the drone, remove the twenty-two 5mm Phillips #1 screws holding the black frame to the body.
    • There is one screw under the rear light. Pry the opaque cover to access the last screw.
  2. Protocol TerraCopter EVO Drone Motor Replacement: étape 2, image 1 de 1
    • The plastic frames are subject to cracking.
    • Wires run through both frames.
    • Pry the white body away from the black frame.
  3. Protocol TerraCopter EVO Drone Motor Replacement: étape 3, image 1 de 1
    • Gently pry the motor from it's socket.
  4. Protocol TerraCopter EVO Drone Motor Replacement: étape 4, image 1 de 2 Protocol TerraCopter EVO Drone Motor Replacement: étape 4, image 2 de 2
    • Locate these solder points of the leads on the motherboard.
    • From the front of the drone, the left motor has red and blue leads.
    • From the front of the drone, the right motor has white and black leads.
    • Remove the leads from their points on the motherboard with a soldering iron, respective to each motor.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with soldering practices.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 9
Total : 199
