Aller au contenu principal
Protocol Videodrone AP Battery Wiring Replacement
Ce dont vous avez besoin
  1. Protocol Videodrone AP Battery Wiring  Replacement, Battery Wiring: étape 1, image 1 de 1
    • Make sure the drone is turned off
  2. Protocol Videodrone AP Battery Wiring  Replacement: étape 2, image 1 de 1
    • Open the hatch and carefully pull out the battery to expose the cable connection
  3. Protocol Videodrone AP Battery Wiring  Replacement: étape 3, image 1 de 2 Protocol Videodrone AP Battery Wiring  Replacement: étape 3, image 2 de 2
    • Carefully pull apart the cable connection
  4. Protocol Videodrone AP Battery Wiring  Replacement: étape 4, image 1 de 2 Protocol Videodrone AP Battery Wiring  Replacement: étape 4, image 2 de 2
    • Unscrew the 4 screws from the bottom of the drone.
    • Unscrew the 8 screws connecting the propeller guards to the drone
    • Unscrew the four propeller screws.
    • One screw is hidden behind the screwdriver.
  5. Protocol Videodrone AP Battery Wiring  Replacement: étape 5, image 1 de 1
    • Carefully remove faulty battery wiring from the drone
  6. Protocol Videodrone AP Battery Wiring  Replacement: étape 6, image 1 de 1
    Outil utilisé dans cette étape :
    • Feed through opening using tweezers to grasp the wire and carefully pull through.
  7. Protocol Videodrone AP Battery Wiring  Replacement: étape 7, image 1 de 1
    • Use the soldering iron to solder new wires to mother board. CAUTION: Soldering iron may get hot and cause minor burns if handled improperly.
    • Use this guide for how to solder: https://www.youtube.com/watch?v=QKbJxytE...
  8. Protocol Videodrone AP Battery Wiring  Replacement: étape 8, image 1 de 1
    • Reattach the battery and test for power by turning on the drone and look for the 4 LEDs turn on.
All Done!
Serge
Membre depuis le 09/26/17
340 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G1, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S2-G1, Passmore Fall 2017
USFT-PASSMORE-F17S2G1
4 membres
3 tutoriels rédigés
3 commentaires de tutoriel
Great explanation. Just wondering where to get the replacement piece. My drone has the black wire hanging by a single strand just outside the white connector. The red wire is in tact but I would need the whole part that attaches to the board and extends outside the drone to connect the battery to. Thanks
yasureok - Réponse
Was wondering i think its charging the blue light flashes when plugged in but wont turn on. Wires look brand new
Michael Landry - Réponse
I’m wondering the same thing, mine lights up blue when charging, wires look good but still no action.
Ryann Hunter -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 10
Total : 1,990
