Aller au contenu principal
Protocol Videodrone AP Camera Replacement
Ce dont vous avez besoin
  1. Protocol Videodrone AP Camera Replacement, Camera: étape 1, image 1 de 1
    • Power off the drone before proceeding with this repair.
  2. Protocol Videodrone AP Camera Replacement: étape 2, image 1 de 1
    • Remove the propeller screws (1 per propeller).
    • You can use the Phillips #0 screwdriver if you don't own the one included with drone.
  3. Protocol Videodrone AP Camera Replacement: étape 3, image 1 de 2 Protocol Videodrone AP Camera Replacement: étape 3, image 2 de 2
    • Remove the screws holding on the propeller guards using the Phillips #0 screwdriver (2 per propeller guard).
  4. Protocol Videodrone AP Camera Replacement: étape 4, image 1 de 2 Protocol Videodrone AP Camera Replacement: étape 4, image 2 de 2
    • Using the Phillips #0 screwdriver to remove the eight screws securing the body of the drone.
  5. Protocol Videodrone AP Camera Replacement: étape 5, image 1 de 1
    • Remove the case.
  6. Protocol Videodrone AP Camera Replacement: étape 6, image 1 de 1
    • Remove the propeller motor screws (3 per motor).
    • The plastic screw housing is attached to the motor.
  7. Protocol Videodrone AP Camera Replacement: étape 7, image 1 de 3 Protocol Videodrone AP Camera Replacement: étape 7, image 2 de 3 Protocol Videodrone AP Camera Replacement: étape 7, image 3 de 3
    • Depress the tab to open the battery housing.
    • Disconnect the battery connectors
    • Remove the battery.
  8. Protocol Videodrone AP Camera Replacement: étape 8, image 1 de 1
    • Using the Phillips #0 screwdriver, remove the four circuit board screws.
    • Remove circuit board.
  9. Protocol Videodrone AP Camera Replacement: étape 9, image 1 de 2 Protocol Videodrone AP Camera Replacement: étape 9, image 2 de 2
    • Remove the four battery housing screws with the Phillips #0 screwdriver.
    • Remove the battery housing to reveal the camera circuit board underneath.
  10. Protocol Videodrone AP Camera Replacement: étape 10, image 1 de 1
    • Pull upwards on the strip to remove the camera out of its slot.
  11. Protocol Videodrone AP Camera Replacement: étape 11, image 1 de 1
    • Remove camera circuit board from housing.
    • On the main circuit board, desolder the the connection points connecting to camera circuit board.
    • Four wires need to be desoldered. Colours include: Red, white, black and blue.
    • For more information on soldering connections, please visit the How to Solder and Desolder Connections guide.
Karan Paranganat
Membre depuis le 11/07/19
352 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G2, Harley Fall 2019 Membre de l'équipe IUPUI, Team S2-G2, Harley Fall 2019
IUPUI-HARLEY-F19S2G2
3 membres
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 8
Total : 388
