Introduction
Prusa MK4 comes with a print fan located on the right side of the Nextruder. It is essential for cooling freshly extruded plastic. However, if the fan is damaged (bearings failure, breaking of the fan blades), it can cause failed prints or severe stringing. This guide will show you how to safely open the Loveboard, unroute the delicate wiring, and swap in a fresh fan.
Ce dont vous avez besoin
Move the extruder to the middle of the X and Y axes to ensure the workspace is clear.
Remove the Loveboard cover from the toolhead and set it aside.
Using a 2.3mm hex insert and tighten the two long 2.5mm screws to secure the fan. Hold the fan tightly, if needed, to make sure there is no gap between the cooling fan and the shroud.
Verify that the screw ends are visible on the opposite side of the shroud to ensure the fan is secured with no gaps.
Once assembled, plug in the printer, turn it on and navigate to Control > Temperature > Print fan on the LCD screen to verify the new fan spins correctly.
