Aller au contenu principal
Puritan Bennett 540 Air Inlet Filter Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Puritan Bennett 540  Air Inlet Filter Replacement, Air Inlet Filter: étape 1, image 1 de 1
    • Hold the filter between your fingers and pinch. Pull the filter outwards (towards you).
  2. Puritan Bennett 540  Air Inlet Filter Replacement: étape 2, image 1 de 1
    • Remove the filter and discard it. Do not save it. When removed, it should look like the attached image.
    • Place the new filter in the device by making sure that:
    • a. The fine particle side of the filter faces outwards, away from the ventilator.
    • b. The filter is properly installed in its housing. Proper installation of the filter prevents particles from entering the device. Remember that the air inlet filter is not reusable; do not wash, clean, or reuse it!
There is no reassembly needed after replacing the inlet filter.
kerribyrne
Membre depuis le 04/08/20
267 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S7-G7, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G7, Paton Spring 2020
CPSU-PATON-S20S7G7
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 90
