Aller au contenu principal
Puritan Bennett 560 Internal Battery Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Puritan Bennett 560 Internal Battery Replacement, Internal Battery: étape 1, image 1 de 1
    • REMOVAL
    • Locate the battery cover on the rear of the ventilator.
  2. Puritan Bennett 560 Internal Battery Replacement: étape 2, image 1 de 1
    • Using the T10 Torx screwdriver, remove the three 8mm screws on the battery cover.
    • Two screws are located on the rear of the ventilator, and one on the bottom.
    • Slide the battery cover out of the ventilator.
    • Remove the battery from the battery cover.
  3. Puritan Bennett 560 Internal Battery Replacement: étape 3, image 1 de 1
    • REPLACEMENT
    • Install the battery into cover, as shown in figure.
    • Make sure the contacts on the battery line up with those in the ventilator.
    • Slide the battery and cover together into the housing.
    • While applying pressure to the cover, install the two rear screws.
    • Install the screw at the bottom of the cover.
    • Be careful not to over-tighten any screws.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Theo Philliber
Membre depuis le 04/07/20
201 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S11-G20, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S11-G20, Paton Spring 2020
CPSU-PATON-S20S11G20
2 membres
3 tutoriels rédigés
Un commentaire
I can’t seem to edit the step titles. They should show:
Step 1: Battery Removal
Step 2:
Step 3: Battery Replacement
Theo Philliber - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 505
