Aller au contenu principal
Puritan Bennett 840 Oxygen Sensor Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
  1. Puritan Bennett 840 Oxygen Sensor Replacement, Oxygen Sensor: étape 1, image 1 de 1
    • Locate the flexible oxygen sensor access cover on the top edge of the cabinet and firmly push the center of the lower flap of the access cover until the lower flap is dislodged from the cabinet.
  2. Puritan Bennett 840 Oxygen Sensor Replacement: étape 2, image 1 de 1
    • Pinch the bottom and top flaps of the access cover firmly together and pull the access cover away from the cabinet to remove.
  3. Puritan Bennett 840 Oxygen Sensor Replacement: étape 3, image 1 de 1
    • Press the small white release tab away from the sensor cable connector to release the sensor cable connector.
    • While continually pressing the release tab, gently pull the connector from the oxygen sensor.
  4. Puritan Bennett 840 Oxygen Sensor Replacement: étape 4, image 1 de 1
    • Unscrew (counter-clockwise) and remove the oxygen sensor.
  5. Puritan Bennett 840 Oxygen Sensor Replacement: étape 5, image 1 de 1
    • Open the replacement oxygen sensor and O-ring. Make sure the O-ring is at the threaded base of the oxygen sensor, and screw (clockwise) until snug.
To reassemble your device, follow these instructions in reverse order. Calibrate new oxygen sensor by pressing 100% O2/ CAL 2 min key. Run an SST to check the system before using the ventilator on a patient.
2 autres ont terminé cette réparation.
Gabrielle Reyes
Membre depuis le 04/09/20
154 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S7-G4, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G4, Paton Spring 2020
CPSU-PATON-S20S7G4
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 24
Total : 1,573
